Sold/Expired 16'' and 18'' coilover springs
zayne2427
There's only one way to find out
Cullman, Al
also need some springs for my coilovers
WTB 2.5 springs for 2.0 coilovers. i have probably 10 springs in the 12'' and 14'' variety in various sizes from 150-400 if anyone needs some
Still looking to buy
2- 18'' 225. (200 if I can't find 225)
2-18'' 150
2-16'' 125. ( 150 if I can find 125)
*2-16'' 100*found Thanks Kevin
Re: Weld in bungs for 7/8 heims and DOM for link bars
I sent you a message last night. I was gonna call you today if I can find weld in bungs. Ive got 4 bungs for 1" ID tube need 4 more. Only place closest enough for a quick drive to pick some up is Blue Torch in Bham. They stock bungs for 1" Inside diameter tube. What tube do you have that will work with that. 2" .500 wall...
Re: 16'' and 18'' coil springs
I won't say I have any better ideas but my buggy is at 4650 lbs with me in it. When I had my shocks measured for coil spring rates I was lil heavy. Basically had same set up you posted above. For sure not saying my setup is better for you but did make a difference in mine. Mine still needs to be tuned badly.
My current set up:
7.5" of shock shaft showing all shocks
Fronts are 125 lbs 16" over 200 lbs 16"
Backs are 100 lbs 16" over 125 lbs 16"
Wayne suggested I needed to run a 14" upper and a 18" lower on the back to be optimal.
top for springs to buy or borrow to get my rig setup
Ryan at Accutune got some of his PAC order in last week. I know you were looking for some #125's at one time. I bought some 14's and he hooked me up on price. You might shoot him a message and see if he's got what you need.
pholmann said:
I believe I have 2 18-2.0-200
let me know if you find out what you have
Will do and I'll send yours back to you. Thanks dor the help
Thanks Kevin. Patrick is hooking me up with some 18" 200 this weekend.
Still need
2- 16" 125
2- 18" 150 or possibly 125
