muchado
I've got a 1978 Landcruiser FJ40 rock crawler for sale. $5,000---will consider trades.
Spec list
2F Six Cylinder 4.2L Engine
• Plugs Replaced
• Plug Wires Replaced w/DUI-HEI Set
• DUI- HEI Distributor
Optima Blue Top Battery
Blue Torch Fabworks battery mount
37-12.5x 15 Goodyear MTR's on 15x10 Eagle Alloy aluminum wheels
Custom Six-Point Rollcage To Frame
Corbeau Seats/Sliders
Corbeau 3 inch Seat Harnesses
Current Wheelbase 104†(stock is 90â€)
• Front Stretched 4.5â€
• Rear Stretched 9.5†– Blue Torch Fab
SOA-Spring-Over-Axle Conversion
Front
• FJ60 Front Axle
• Front Shackle Reversal
• Spring over axle conversion
• Hi-Steer Set-up
• HD Tie-Rods w/FJ80 Ends
• FJ60 Powersteering Gearbox Conversion
Rear Cherokee XJ Spring Set
FJ60 Tilt Steering Column
Front Brake Rotors/Pads/Calipers Replaced
Rear Cylinders/shoes replaced
Clutch Master Cylinder Replaced
Clutch Disc/Pressure Plate/T.O. Brg Replaced
Original Hardtop
Doors
• Front Original Hard Doors
• Spare Set Front Hard Doors
• Rear Ambulance Hard Doors
• Rear Half Doors
Twin Tow Shackle Points Front & Rear
LED Rear Tail Lights
Clear ***le
Everything on motor is stock except for the DUI (davis unified ignition) distributor. The engine bay is very clean---and the frame has no rust. Body is in OK shape but by no means mint--there's dings and body filler spots. We bought this landcruiser in Texas so the frame has not been through Kansas salt road winters.
Needs shocks, and steering pump rebuild but otherwise is a solid rig. We will entertain trade offers as well.
$5,000---will consider trades... Located in Stilwell, Kansas.
PM or Email [email protected]
Spec list
• Plugs Replaced
Front
• FJ60 Front Axle
• Hi-Steer Set-up
Original Hardtop
Doors
• Rear Half Doors
Clear ***le
