kmcminn
- Joined
- Nov 9, 2009
- Messages
- 5,923
- Reaction score
- 142
LC engineering EGR deletes. New timing chain, new seals gaskets, fuel pump, plugs, hoses and belts. New rear brakes. New shifter bushing. New head gasket , head has just been reworked also. New ignition switch, new starter, new battery. Gm coil and ignition module.
The bad, rust has patched in driver floorboard, rust in driver side bed has been bondo'd over. Brakes need bleed again. Has clunk when you dump the clutch. Horn doesn't work. Dash bezel is out.
It is not a new truck. But the thing runs good and drives good.
Call for additional details. Located in Cullman Al.
SOLD.
