Sold/Expired 1986 mega chevy mud truck
Hardline Crawlers | Rock Bouncer Builds, Tech & Off-Road Trail Talk
Hinkle202
Member
86 chevy, 4 link, 1.25 heims, 14" FOA coil covers, cyclone transfer case, 383 stroker, Chevy race bow tie block .40 over, 4 bolt, 1 piece seal, all forged internals-crank, arms,pistons,hydraulic roller cam, ceramic coated hooker headers, high volume oil pump, Dart pro 1 platinum aluminum heads 202's, comp cams 1.6 magnum roller rocker arms, comp cams pro magnum hydraulic roller lifters, comp cams gear to gear timing, comp cams 2 piece timing cover,hurricane high rise intake, quick fuel 1050 carb, dual fuel filters, inline high pressure fuel pump, fuel regulator w/ pressure gauge, MSD ignition,distributor, blaster coil, RPM rev controller, and wires. March serpentine setup. Meziere elec water pump, dual radiators( one in front and one in bed) w/ dual Flex-a-light fans, derale tranny cooler with fan, 14 gallon aluminum fuel cell, dual batteries with on-off master switch, turbo 400 w/ stage 3 shift kit, derale performance transmission pan, b& m truck shifter, DIY brake kit on rear axle, on-off switch cluster for electric water pump, radiator fans, and tranny cooler fan. Gauges include Rpm, water temp, oil pressure, volts, tranny fluid temp. Hydraulic steering. All this sitting on 24x10 custom powder coated wheels with 14.9x24 BKT 171's. Selling it cheap!!!!! Lots of $$$$ invested
15,000. Obo. Possible trade for trail buggie/crawler/bouncer
Location zanesville Ohio
7408193382- sam
