Hilbilly82
- Joined
- Oct 3, 2012
- Messages
- 69
- Reaction score
- 0
I have for sale a 1987 Jeep Wrangler YJ. Its used as a mountain jeep. Needs some TLC to be a regular street jeep again. I occasionally drive it on the road to the store and back. Its a dependable jeep. I have put a lot of time and money into it, but I just bought a cherokee and I am fixin to start in on a house. It has aftermarket hardtop and upper doors. Besttop seats. Since I have owned it I have put new radiator, hoses, waterpump, cherokee serpintene belt sys. Cadillac high output alternator, ford 300 ci distributor cap/rotor button. Ford coil, msd box, motorcraft 2bbl carb, cherokee plug wires, new plugs, big blower motor for heater, just put on new master cyl. And front calipers. Has ford T18 trans with newer hyd. slave cly. And clutch disc. Np231 with slip yoke eliminator. Ford explorer 8.8 rear with disc brakes and 4.10 gears front and rear are welded front has posi lock. I put rancho wagoneer springs front and rear to stretch wheelbase 4 inches. Extended braided brake lines. I put jeep tj flares on it to open up wheelwells. I installed tj rubicon rocker guards and cut rockers about an inch to raise them higher. Has 295/16 hankook dynapro mts. Solid bodied jeep. Like I said needs a some tlc to be a road jeep again, I have sunk way more in it than I will ever get out of it. Just gonna cut my losses and let someone else finish a good jeep. Call or text David at 2 five 6 seven 8 three 3 six 3 zero. Located in New Market, AL
