M_ENERGY2014
New Member
- Joined
- Aug 11, 2016
- Messages
- 3
Clean ***le in hand
1990 Toyota reg cab, bed bobbed 13"
3.4l swap, 5sp
New T100 rear sump oil pan
Trail gear bomb proof motor/tcase mounts
New radiator
New battery
New master cylinder and disc/disc proportional valve
New crossover exhaust pipe for passenger side exhaust
Trail gear adapter, toy reduction box
Inch worm adapter for dana 300 flipped
Twin stick cable shifters
New Carolina driveline driveshafts front and rear
Flatbelly 1/4" skid plate
Trail gear hydro assist full kit
8" ram
Steering box is tapped
Flat pitman arm
Suspension
Front - RUF with Sky's offroad front hanger
Rear - 63" chevy
Axles
Front - Kingpin HP 60 5.13 gear spool
35 spline inner/outer cromo axle shafts
Yukon hubs
TMR chevy disc brake kit (matching front and rear caliper/rotors)
Skys offroad highsteer arms (toyota ackerman)
New drag link and tie rod w/heims from barnes 4wd
HD barnes 4wd diff cover
Braided steel brake lines
Rear - 14 bolt
5.13 gear Detroit locker
Disc brake kit
Barnes 4wd HD diff cover
New fuel cell
New fuel pump E2000
NEW
17" Raceline Monsters
39.5x13.5x17 Irocs
1 used spare Iroc
XRC 10,000lb winch w/synthetic rope
TMR poly bumpstops
TG shock hoops front - new
2 Bilstein shocks
SOLD
Pickens, SC
CALL OR TEXT ONLY!! NO TRADES!!
Sent from my SM-S902L using Tapatalk
3.4l swap, 5sp
New radiator
New battery
8" ram
Flat pitman arm
Suspension
Rear - 63" chevy
Axles
Yukon hubs
Rear - 14 bolt
Disc brake kit
New fuel cell
New fuel pump E2000
NEW
39.5x13.5x17 Irocs
1 used spare Iroc
TMR poly bumpstops
2 Bilstein shocks
SOLD
Pickens, SC
