1
10grandyota
Guest
1990 Toyota 4x4 Crawler/Driver
4340 rear axles, Longfield super 30 front axles , Longfield hub gears , Longfield transfercase output shaft , Marlin Crawler 23 spline 4.7 HD gearset , Inchworm dual case adapter stock 2.28 crawl box , 5.29 gears and Detroit lockers front and rear , front and rear axles fully gusseted , 4 wheel 4 piston disk drakes ,Trail Gear Hydro ram assist high steering ,Trail Gear Trunnion bearing eliminator kit . ARP knuckle studs , Trail Gear long spline front drive shaft , Allpro transfercase brake ,Fully built 22re, Keithblack pistons Engine Builder RV head with bigger valves and 261c crawler cam ,ARP head studs , DOA metal timing chain guides , LC Enginering injectors , LC Enginering 35lb flywheel witn Marlin Crawler clutch set , LC Enginering air intake kit , Trail Gear sainless steel full length header with Magnaflow converter and Flowmaster muffler, custom 6" lift with Bilstien long travel shocks , 37x14.50x15 Toyo open country mud tires on 15x10 Procomp rockcrawler wheels , custom front and rear bumpers and rock sliders , Warn 8000lb winch.
There is well over $15000 in parts alone so no low balling !
Truck runs and drives good and passes hamilton county emissions
$9500 or trade for 4runner , grand cherokee , rhino , rzr
