FlatlandFSJ
KEEPING THIS
Not for sale now.
**I'll get outside pictures posted and explained tomorrow after I wash it. Just need to get it posted, and I can use this for the craiglist ad to
1991 'Burb. 350/700r?/208/10 bolts f&r. Frame mount hitch/barn doors/3rd row with the rear ac/heater panel. Two hundred and some change on the body, newer motor has maybe 85k miles on it and the accessories.
The original tbi 350 had a bottom end knock when I got this. Just swapped in another tbi 350 that was stashed in storage. it was converted to carb a while back in a friends truck using an edelbrock alum intake and carb.
The old tbi stuff will be included with it, I left the entire harness alone so it shouldn't be to big of an issue to swap the intake and drop the tbi back on it.
Motor runs good, did plugs&wires when I dropped it in. Haven't fully tested the trans but it goes backwards and forward. Sorta new radiator.
Interior has seen better days, but it's not the worst square body inside I've seen by a long shot tho. Missing some little things up front, window switch on one door, and some screws to hold the arm rest on the driver. The driver seat is pretty worn out, I'll be swapping in a newer set before it sells, along with fixing the other small things missing up front.
Headliner is missing the rear section, the wood backer is still there but the fabric and foam are gone. Driver rear door has a broken interior panel.
Body has some rust in the rear fender wells down low, but the underside and the lower door jams are rust free. Drip rails are solid, 1 small rust spot in each upper door jam near the top back corners.
I'll be removing the running boards since the passenger side is missing the end caps, I'll toss them in the truck if the buyer wants them.
*****Going to keep working and cleaning on this until it sells. Posted price won't move much, but I'd take less of an offer now then I will after I get it fixed up a little bit.
That being said.... ***@%#^ OBO*** NW Florida, can help with getting it somewhere further north. Might trade depending on what it is....pair of steering rocks/ chassis/ decent set of tons(pass drop)/ tools/ flat fender jeep
/ no guns please, i really don't need them.
Front
3rd row
2nd row & broken door panel. You can also see the messed up driver seat that will be getting replaced.
Back passenger door. Most of the panels have little scuffs, pretty sure it was some dudes work truck.
Passenger door. I've got a buncha parts for these things, I'll be getting the little clips and covers replaced as I find them.
Nothing to bad in the jam, they all have a spot about like this one.
Worst of the fender rust, might have patches that can go with it. Passenger side is not as bad. Has alum bullet hole rims, steely/bfg are a spare.
Not for sale now.**I'll get outside pictures posted and explained tomorrow after I wash it. Just need to get it posted, and I can use this for the craiglist ad to
.**1991 'Burb. 350/700r?/208/10 bolts f&r. Frame mount hitch/barn doors/3rd row with the rear ac/heater panel. Two hundred and some change on the body, newer motor has maybe 85k miles on it and the accessories.
/ no guns please, i really don't need them.Front
3rd row
