Sold/Expired 1997 ram 3500 800 horse trade for crawler
Jben86
New Member
Truck started as a 2.6 pulling truck and ended up a very nasty street truck. The dash is currently out and need to have a non cv driveshaft made in the front for the new yolks. This is not the usual "built Cummins" it is a legit 800 horse truck built to be a full on race engine. I have receipts for the drivetrain and over 50k in it to this point. It's been redone from the ground up. Looking for partial trades with cash or even trades for crawlers. Price and trade value is 25 k as it sits. It is street able the way it is
LOOKING FOR TRADES ON BUILT ROCK CRAWLERS
97 ext cab long bed 4wd 5 speed all done in less than 2000 miles..0 hooks or drags
BOTTOM END
All clevite race bearings and arp hardware
Arp 12 mm head studs and rocker studs
New tappets
Billet pushrods
Cryogenically stress relieved rods
Mahle flycut pistons..coated tops and skirts
Rotating assembly balanced
Billet colt cam 181* intake 210* exhaust
SFI fluid damper
Haisley billet front cover
Billet freeze plugs
Haisley keyed adjustable timing gear(set at 26*)
Fire ring 50% block 50% head
14mm main studs and girdle
HEAD WORK
Full port and polish (removed 6+ lbs of material)
Oversized stainless valves
New rockers
Dual beehive valve springs
Steed speed t4 exh. Manifold
Billet intake plate w grid heater delete
Pusher intake runner w 4 ports
AIR
S400 67/74 w 2.6 housing and billet 6 blade impeller
Hogan 4 " core air to air cooler
Haisley hd boots
FUEL
Airdog 2 200 gph
.093 injection lines
DDP stage 4 honed extruded injectors
13mm p7100
Fast rate cam 131 deliveries .35 holders
5000 rpm springs
Driveline
241 dhd and billet shaft nv4500 built by a&b transmissions
South Bend dual disk 3850
Stock dana 60&80 w 4:10 gears
1 piece rear drive shaft 1410 joint and 1480
Set up for 1410 joint front shaft (not included)
New radiator and dual elect. Fans
Complete mooge front end w all bars and hubs
Rebuilt vacuum pump
Dash removed rear seat and belts removed (have seat and belts)
Entire body replaced w Alabama donor. No mud or foam anywhere
New paint by Bruce Miller ( painted OFF CONSTANTLY)
Isspro gauges w 6 k auto meter diesel tac.
single battery setup.
Eby aluminum flatbed ..sport front end and cowl hood.
5" downpipe back exhaust
All factory wiring in cab is intact for a dash install.
New 17" rock Stars and mxt mud terrains
