Sold/Expired 1997 toyota tacoma ext cab 4x4
CheapJ7
Mustache rides?
Jasper, al
Found another truck i'd like to have, so the Turtle has to go.
1997 toyota tacoma
Tan interior
4 cyl 5 speed
manual hubs and transfercase Non add
3in body lift
rocklights
downey long tube header with full exhaust system (not loud)
Full cold air intake
200k plus miles but only about 50k on engine and drivetrain rebuild
Engine pulls strong, doesn't smoke, use oil, or make any noise.
The bad:
Bushing needs replaced where steering shaft goes through the firewall. Gives the steering some slop. Simple fix
A/C needs an oring replaced where the line comes out of the condensor.
outer shifter boot is torn.
Previous owner was a BIIIIGGGG fellow. Driver seatbelt was cut in half and the limiter on how wide the door opens is removed.
The truck currently has 35 bfg km2's on black soft 8's
I will sell it with the 35's for $5500 or $4900 with steel wheels and 31in street tires.
Truck is located in Jasper al
Reply, call or text 205 522 4591 Thanks Jon
index.php
