2000 Jeep Cherokee $12,500 obo
-4.0liter motor,
Odyssey rear mount battery with Ruff Stuff tray, fresh plugs and oil change, 22 gallon fuel cell with Airwerks fuel pump and a Saturn Fuel filter Regulator
Full internal roll cage built by Huffman’s Fab with door bars and a front bar braced into the front bumper and the coilover towers.
Ruff Stuff mid and front frame stiffeners, rear hooligan stiffeners
Custom built boat sides with 3/16” 2x6 slider and 2x2 kickers played with 1/8” plate
Corbeau front seats, extra wide, and PRP 5.3 harnesses
-Aw4- transcooler and RA Designs manual shift
-NP231- AA SYE, JCR skid plate, 1410 rear WOD DIY driveshaft with 2.5” .25 wall tube
Axles1993 Ford Dana 60 front new Moog Ball Joints
5.38, welded carrier, RCV 4340 front shafts, Crane front drive slugs, Full Artec front truss with dual ended ram mount and all tabs and brackets, and Ruff Stuff front diff cover.
-1986 14bolt, 5.38 gears, nitro 30spline spool, full Artec rear truss with pinion tie and pinion support, Artec rear back bone truss and all tabs and brackets, Barnes 4wd 13 bolt shave cover
Suspension
-113” wheel base
-4 link front and rear, with 3/4” ruff stuff heims 1 1/2 .25 wall uppers
1.25 Rockwell off-road heims with WOD rear aluminum links and front 2” .25 wall steel front (have a set of aluminum lowers that need to be trimmed to fit for front)
-2” Radflo coilovers 14” front and 16” rear
-2”, 2” travel Radflo front air Bumps and Fox rear air bumps
-WOD limit straps on all 4 corners
-Currie Anti rock rear sway barLighting
-42” light bar under the windshield
- 2-7” light bars for the headlights
- Lux lighting 8 light rock lights with magnetic bases so you can move them where you want
Wheels
4x-17x8 Trailready aluminum beadlocks
4x- 39x13.5r17 red label krawlers 85% tread no plugs or patches
-trimmed for 43s
Jcr front DIY bumper with a Boostwerks front comp winch tray
Smitty built 9500lb winch
Located in acworth ga
Call or text will any questions
7708560334
Patrick
-4.0liter motor,
Suspension
-113” wheel base
Wheels
-trimmed for 43s
7708560334
Patrick
