Sold/Expired 2.0" S.A.W. 16"Air Shocks
  • Thread starter Thread starter InDaShop
  • Start date Start date
I
InDaShop
Guest
For Sale a pair of used
2.0 Sway-A-Way 16" Air Shocks, and mounting hardware (misalignment spacers, and 1/2 bolts and nuts.)
I noticed taking pics 1 Shock has the upper eye area kinda tweaked, I will throw in another used end to replace.
$325 plus shipping for the pair of airshocks
Stock photo from PolyPerf
Racerunner 2.0” Air Shocks were designed with the most extreme Rock Crawler in mind, and offer incredible stability and control over the most demanding rocks any trail has to offer. RaceRunner Air Shocks come standard with Com10 Teflon lined steel spherical bearings, 1 3/8” hard-chromed chromoly tubing, and O-ring Schrader valves. RaceRunner Air Shocks offer full adjustability from 50-500psi, supports up to 1000lbs per corner and come standard with smooth Nickel plated cylinders.
Travel (in)- 16"
Extended Length (in)- 38.94"
Collapsed Length (in)- 22.99"
Shaft (in)- 1 3/8"
Cylinder Type- Smooth
