Sold/Expired (2) 14" Profender 2.5 Triple Rate Bypass Shocks
haustow
Tampa, FL
(2) 2.5" Profender 14" Triple Rate Bypass Shocks (2 compression tubes, 1 rebound tube). 24" collapsed, 38" extended. Bought for a project and have sat on the shelf ever since. 1 shock looks great with just typical wear on the ends. 2nd shock also looks great, but has a small crack on the remote reservoir tube where it is welded to the shock body. Looks like it was dropped and cracked 1/2 of the weld. You can re-weld the crack or just buy a new body direct from Profender and you would have a like new shock. The piston and wear ring were damaged because the bent tube caused very minor interference with the piston. However, I am INCLUDING TWO brand new pistons and wear rings with the sale (for some reason I bought 2?). These shocks list for $575/each from Profender.
Price is $600 shipped to lower 48. Located Tampa, FL
