rthill97tj
Member
- Joined
- Aug 22, 2009
- Messages
- 22
- Reaction score
- 0
I have a 2000 Patriot Blue Jeep Wrangler TJ Sport model I6 (inline 6cyl) with A/C and 5 speed manual trans and full doors for sale with 207K miles, wouldn't believe it when seeing it. $7,200 or make offer (no trades). Jeep has the optional strong rear Dana 44 and gears front and rear were just recently (less than 800 miles) changed to 4.56 gears. Also at the time all bearings and seals were replaced. Jeep was origainally purchased in Georgia and has spent it's whole life here so is very clean underneath. body has some scratches and a small dent in hood. Paint on hood has slight crack marks like all these year models do. Owned by a 15 year Chrysler tech. Here is a list of things installed in the past year/2k miles plus the gears mentioned above:
--Skyjacker 4" suspension
--JKS mfg 1.25" body lift (to clear high clearance skid plate)
--motor mount lift to level to body and gain clearance
--Rock crawler front and rear bumpers
--Bestop front and rear seat covers
--K&N filter system with precleaner
--Drake offroad shifter knob
--tie rod and alignment less than 200 miles
--Mopar/Chrysler timing chain and sprockets
--Replaced valve cover gasket, rear main seal, oil pan gasket, timing cover
gasket, engine emission hoses, upper and lower radiator hoses, and
spark plugs with Mopar/Chrysler parts less than 1k miles
Tires are the only thing that is needed. I had 35s on it (33s on it now and in pic) but it would probably clear 37s. New gearing would be good for either. This is a clean jeep and is super clean underneath. I am selling because I was going to build it into a crawler but have a Unlimited TJ and don't need two jeeps. located in Cleveland, Ga. Clear ***le in hand
