1slowhatch
- Joined
- Feb 21, 2012
- Messages
- 420
- Reaction score
- 0
2003 Ford F250 Crew Cab Short Bed Lariat 4x4 180k miles, reliable 5.4 gas engine and automatic transmission. Engine runs great and transmission works as it should, shifts great, no slipping. Since I've owned it I've replaced: Premium Moog ball joints, Timken hub bearing, transmission fluid and filter change, new bed liner, new sway bar end links, sway bar bushings, etc. The truck also has tinted windows, and billet grill. It's an '03, so it has the D60 front, and the updated cylinder heads (no more spark plug issues).
The truck has been used as a work truck, so it has some scratches and dings. Also has dent in front fender (see picture), and clear coat is messed up on the tail gate. Interior is in good shape, but could use some cleaning. All power accessories work as they should. Hot heat, and cold A/C. Will need transfer case switch for 4 wheel drive to engage. May need a hub bearing soon on the passenger side, and alignment. Windshield also has a crack.
Good condition KBB is over $9500.
I am asking $7850. PRICE DROPPED TO $7650 OBO! Will consider trade for one ton yj or tj.
Pictures http://knoxville.craigslist.org/cto/3179234458.html.
Clean ***le in hand. Serious inquiries only please. Located in Knoxville, TN.
