Hotrodpayton
Jesus Saves
- Joined
- Oct 22, 2012
- Messages
- 504
I have a 2003 Toyota Tacoma 2x4. The little one with a 2.4 L 4 cyl. It's a 5 speed and its the one with the 5 lug rear end, 7.5'' ring gear. Anyone here know if a 4x4 transfer case from the same year truck will bolt to the trans? or If I can swap to a 4x4 trans an t case from a donor Tacoma? Only issue is to make it a straight axle, the pinion is on the wrong side for a new model trans and t case. Sooooo, will an old model trans and t case bolt up? If so, I think the clutch parts are on the wrong side. What is the best idea?
