P
Prime78
Guest
Tie Down Pockets, Sides & Front
• 2†Tubular Stop Rail
• Floor Secured w/Torx Screws
• Cambered EZ Lube Axles
• Two 5,200# Cambered Axles w/Electric Brakes
10ET
Pro Series Tandem Axle Equipment
G.V.W.R. 9,990# AXLES Two 5,200# EZ Lube w/Electric Brakes
G.A.W.R. (Ea. Axle) 5,080# SUSPENSION Multi-Leaf Spring w/Equalizer
COUPLER Adjustable Forged 2-5/16†TIRE ST225/75-15 Load Range D
SAFETY CHAINS 1/4†Grd. 70 w/Safety Latch Hook (2 each) WHEEL 15 x 6 White Spoke 6 Bolt
JACK 7K Drop Leg (Bolted On) FLOOR 2†Pine
TONGUE 5†Channel Fold Back LIGHTS D.O.T. Stop, Tail, Turn & Clearance
TOP RAIL None ELEC. PLUG 7-Way RV
FRAME 5†Channel FINISH (Prep) Steel is Cleaned to Ensure a Professional
CROSSMEMBERS 3†Channel Smooth Finish.
UPRIGHTS None FINISH Superior Quality Finish is Applied for a Highly
FENDERS 9†x 72†Tear Drop w/Back (Removable) Decorative and Protective Finish.
Standard Features
• Adjustable Forged Coupler
• Safety Chains Attached w/Cold Rolled
Eyelets
• 7K Drop Leg Jack
• Lower Jack Support Plate
• Fold Back Tongue (14’ and longer)
• Complete Break-A-Way System w/Charger
• Spare Tire Mount
• 32†Dovetail
• 5’ Stand-Up Ramps w/Support Leg
Trailer also comes with tool box mounted up front and 2 spare tires.
$2,200 Firm, Located in Birmingham, AL. PM for any questions
10ET
Standard Features
Eyelets
• 7K Drop Leg Jack
• Spare Tire Mount
• 32†Dovetail
