Sold/Expired 2013 Jimmy Smith turn key turbo bouncer
bbaxter51
New Member
Listing this for a friend. This buggy is a ZERO expense spared build.
(Still waiting on specific details so I'll update when I get those. Here's what I can remember)
Jimmy Smith built the chassis and made it a roller. Finished in 2014.
Rockwell axles loaded with ARB front, Rear Spool, Overson axles, Super 8 hubs and pinion brake setup with Wilwood Caliper.
Willwood pinion brakes.
4 Wheel steering with all PSC everything and dual pumps.
5.3 Truck LS motor with a 74mm Precision Turbo setup for e85. Also setup for water Meth injection (640hp, at the rear wheels; detuned at 14psi.)
TH400 with Reverse Manual Valve Body, built my Master Transmission in Roseville MN, full billet converter.
Summit Machine Works 203/205 doubler
2.5" 18" long FOA coil overs
49" Iroks with MRW 17" double bead locks.
ARC switch panel and fuse block.
ARB air pump
Power steering coolers
trans cooler.
Chassis is Camaro green
The details on this rig are amazing. Alum clamps for the hydro lines, all AN braided EVERYTHING. The exhaust/turbo system is a work of art. Wiring doesn't get any cleaner. Motor professionally tuned.
I'll update the thread with any other details I get from him tonight along with any detailed pics. Less than 10 rides since new. Located in Hastings, MN Suburb of Minneapolis/St.Paul
60k More info, call Mark (612) seven49 443zero
