I have a brand new trailer that I ordered for myself and through a series of miscommunications it came in 6ft shorter than it should have been. I took that trailer on one trip to hotsprings and it did great. It has not been ***led, the buy will the the original owner. Retail price on this Trailer is $6500.00
I will sell it for $4500 + 7% tax and a $10.00 ***le fee. If you are in Mississippi, if not this does not apply.
Here are the specs:
8 ft 6" x 22 ft Utility Trailer
Year: 2013
Manufacturer: LoadTrail
Model: LTGB10222
Axle Type: Tandem Axle
Hitch Type: Gooseneck
Color: Black
Vin #: 4ZEGC2225D1036570
OPTION: Spare Tire Mount on the Front of the Neck
OPTION: 2nd Tool Box in Top of GN
where the spare normally goes
Weather Tight
OPTION: Winch Plate all the way acroos the front of the trailer
OPTION: Front Mount Tool Box
OPTION: LED Lighting
OPTION: 6 Additional D-Rings
Put D-Rings Every 2FT
22 D-Rings in all
OPTION: Drive-Over Fenders 10" (weld-on)
Ramps: 5 FT Slide-In Ramps 5FT x 13"
Frame: 8" Channel (11.5 lbs/ft)
Crossmembers: 3" Channel (3.5 lbs/ft)
Tongue: 10" I-Beam (12 lbs/ft)
Neck: 10" I-Beam (12 lbs/ft)
Specifications:
GVWR: 14000 lbs.
2 - 7,000 lb Drop Torflex Dexter Axles
Electric Brake Axles On Both Axles
Torflex Suspension
Coupler:2 5/16 " Adjustable Gooseneck Coupler (20,000 lb.)
Jack: 2-10k Jack Spring Loaded Drop Leg
Floor
ressure Treated Floor
Tires:ST235/80 R16 LR"E" 10 ply Tires
Wheels: 16" 8-Hole White Spoke
102" Wide
3/8 x 2" Rub Rail with Stake Pockets and Rail Supports
Call or text Chris Barron
601-260-1070
Here are the specs:
Year: 2013
Model: LTGB10222
Color: Black
Weather Tight
22 D-Rings in all
Specifications:
GVWR: 14000 lbs.
Torflex Suspension
Floor
102" Wide
601-260-1070
