richardsonsfab
Member
- Joined
- Oct 26, 2014
- Messages
- 8
2013 ROCK BOUNCER/ TRAIL RIG
Lowered price to 25,000
ENGINE/CHASSIS
350 tune port out of a corvette with around 55k
aluminum heads and roller camshaft
converted to propane
coated headers
duel exhaust with duel mufflers coated
msd ignition
130 amp alternator
optima red top battery
rear mounter rad with electric fans
chassis is all 1-3/4 dom tubing
all floor pans are coated with bed liner
all auto meter 1-5/8 gauges, water temp, oil preasure, trans temp, and volts
5 inch auto meter tach
overhead switch panel
steering cooler with fan
corbeau seats with rjs belts
30 inch led light bar
warn 8000lb winch with synthetic rope
112inch wheel base with 21inch belly height
TRANNY/TRANSPHER CASE
Th400 completely rebuilt
b@m billet shifter
capable of handling 800hp
remote tranny cooler with fan
atlas 2 speed, twin stick, 3.8 ratio
FRONT AXLE
gm dana 60
5.13 gears
Detroit locker
Yukon chromoly inner and outer shafts
Yukon 300m super joints
Yukon 300m drive flanges
off road design high steer arms
psc full hydro steering
tom woods 2 piece custom driveshaft
REAR AXLE
gm corporate 14 bolt
5.13 gears
Yukon spool
disc brake conversion
tom woods rear driveshaft
SUSPENTION
king 2.0 emulsion 14inch travel coil overs
king air bumps on front
limit straps front and rear
custom 4link front and rear
2inch 1/4 wall upper bars with 1-1/4 heim joints front/rear
2-1/4 3/8 wall lower bars with 1-1/4 heim joints front/rear
WHEELS/TIRES
39.5x18.00/16.5 tires on h1 dual bead lock hummer wheels
re centered with trail worthy fab centers
trail worthy fab Pvc inserts
trail worthy fab rock rings
CONTACT INFO / LOCATION
Fred Richardson
724-378-2056
Pittsburgh pa
please call if you have any questions about anything
ENGINE/CHASSIS
coated headers
msd ignition
130 amp alternator
b@m billet shifter
FRONT AXLE
gm dana 60
5.13 gears
Detroit locker
REAR AXLE
5.13 gears
Yukon spool
SUSPENTION
WHEELS/TIRES
Fred Richardson
724-378-2056
Pittsburgh pa
what magazine did you look at to build this thing POPULAR SCIENCE OMG.
