ECGS
New differential covers for the 2014+ GM9.5b/9.76 12 bolt rear axle.
Cover works without spacer with True Trac and similar aftermarket carriers, which are required when changing to 4.56 or numerically higher on 9.5 and 4.10 and numerically higher on 9.76.
Bracket for parking brake cable probably needs to be slightly moved or bent.
Differential Cover Features:
*Increased oil capacity for cooler temperatures
*Sand-cast aluminum with raised fins
*3/16-inch thick wall construction to add strength to differential housing
*3/8-inch thick gasket flange will not bend when bolts are tightened
*Machined gasket surface for a secure seal using RTV or factory reusable gasket
*Oil changes without removing the cover
*All hardware provided, including magnetic drain plug
For more information and pricing visit:
http://eastcoastgearsupply.com/i-23993273-gm-9-5-9-76-differential-cover.html
For all 14+ GM12 bolt products visit:
http://eastcoastgearsupply.com/c-963800-gears-install-kits-carriers-spider-gears-general-motors-gm-9-5-12-bolt.html
If you have any questions about regear or conversions on 2014+ GM 1500 Vehicles give us a call 919-672-2705.
