SOLD pending pick up This is a Brand new car with less than 5hrs.. Has only been ran enough to verify that there are no cooling/clearance issues. This is the same chassis/suspension setup as the spec cars that jessie combs Won her class with @ KOH. That said, this car was not setup to race, some things could easilly be changed/added to make it race ready but this car was built more for reliabilty and comfort than speed.. in my opinion you would be hard pressed to find many cars put together as well as this one. Randy and his crew put alot of attention to detail in this car and it speaks for it's self.
2014 Jimmy’s4x4 Trail Series 2 seater
Chassis:
Jimmy’s4x4 Full width Trail series chassis (2.0"x.120W DOM) (58” wide)
*CNC bent & laser notched
Powder coated Peeka blue metallic
*Extra fill bars
*Head Mounts on Engine
*Front and rear pre run bumpers
*Full engine skid with UHMW skid
*Laser cut/dimpled mounts on everything
Jimmy’s 4x4 Aluminum interior
*Roof (Powdered Heavy silver)
*Floor (Powdered texture black) (Dzuz clipped for easy removal)
*kicker panels
*Firewall
*Full console/dash (Dzuz Clipped for easy removal) (Powdered Heavy silver)
Jimmy's4x4 Full width Jeep JK body (Front/Rear Fenders)
Custom Painted/airbrushed (Heavy silver/ Peeka blue graphics and lots of candies)
Motor:
GM Gen III 5.3L LS
LS2 Intake
FAST Big Mouth 90mm Throttle Body
FAST LS2 Injectors
Holley billet fuel rails
PSI harness/ECM
8qt Camaro pan
5” Cone Air filter
New Water pump modified with AN fittings
New Alternator
Polished Thorley Headers
Polished 2.5” Magnaflows w/ polished heat shields
Moroso 3qt accumulator with Improved racing adapter
Transmission:
GM TH350-HD
K Case
7075 Aluminum Fwd Drum
300M input/output
HD center support
Reds and kolene steels
Reverse manual Valve body
Art Carr/Winters shifter
Locking dipstick
Derale Dual pass Trans. cooler w/Elec. Fan
Transfer case:
Atlas 4 speed
Cable shifters
1350 Yokes
Axles:
Front:
Ruffstuff specialties Housing
3/8’s DOM Tubes
Jrat 69 Third
RCV 300M shafts
Yukon 4340 flanges
Spidertrax 14” pro series rotors/hats
Solid 6 lug Hubs
Solid C’s
Solid Kingpin Knuckles
Keyed 6-stud Aluminum high steer arms
Yukon Spool with 5.38R Ring and Pinion
Rear:
Jrat 69 Third
3/8 DOM tubes
Solid Spindles
Solid 6 lug hubs (full float)
RCV 300M shafts
Yukon 4340 flanges
Yukon spool with 5.38R Ring and Pinion
Suspension:
Triangulated 4 link front & rear
Jimmy’s 4x4 laser cut mounts on everything
Summit machine 7075 aluminum links
-1.75” Uppers w/ 7/8” chromoly rod ends (front/rear)
-2.25” Lowers W/1.25” chromoly Rod ends (front/rear)
Double sheer Anodized Aluminum swaybar (Rear) With caps instead of snaprings
Radflo 2.0 Coilovers and 2.5 3 tube Bypass’s (front/rear)
Radflo 2.0 air bumps @ all 4 corners
Steering:
PSC 2.5 Double ended ram
PSC Valve
PSC Pump
PSC Remote Res
Derale single pass steering cooler w/ Elec. Fan
Joe’s steering wheel w/disconnect
Brakes:
Dual Wilwood masters
Wilwood pedal assy.
Wilwood 4 piston calipers (front/rear)
Russell braided lines/fittings
Tires/Wheels:
4- 17” Raceline’s (6 lug)
4- New 39” Red label Krawlers (comp compound)
Fuel:
RCI 16 gallon Enclosed in aluminum
Fast fill kit
E2000 pump
Dual Walbro in tank pick up’s
Pre/post AN filters
Malory regulator
Aeroquip line/fittings
Misc:
CBR 31x14x2.25 Dual pass Radiator (front mount)
Dual Spal electric fans on t-stat
Warn VR 10,000 winch w/ synthetic line
40” E Series" LED Light bar in tube Cradle
LED Rock lights in each corner
KC Highlight headlights
Autometer gauges (Tach, oil, temp, volt)
Custom Twisted stitch seats w/ Harnesses
1350 2.125 X .188W DOM Driveshaft
Master kill switch
Odyssey battery
Rubbermade 8 gallon Action Packer in rear with mount
Igloo cooler in rear with mount
Twisted stitch limit straps
There are a bunch of detailed pics in the album below for those interested:
Jace Baker's (jaceb_03) Library | Photobucket
SOLD pending pick up..
As i said before this is a new rig and has only been ran enough to check for the usual new car issues... If you're in the market & have been on the fence about buying yourself a new toy here is you're chance to get one @ a used car price without any wait....
Car is located in Mt.pleasant, TX 75455
Please feel free to call or shoot me a text @ 903-563-5454 if you are seriously interested. You can also pm me on here or shoot me an email at [email protected]
Chassis:
*Extra fill bars
*kicker panels
*Firewall
Motor:
GM Gen III 5.3L LS
LS2 Intake
FAST LS2 Injectors
PSI harness/ECM
8qt Camaro pan
5” Cone Air filter
New Alternator
Transmission:
GM TH350-HD
K Case
300M input/output
HD center support
Locking dipstick
Transfer case:
Atlas 4 speed
Cable shifters
1350 Yokes
Axles:
Front:
3/8’s DOM Tubes
Jrat 69 Third
RCV 300M shafts
Yukon 4340 flanges
Solid 6 lug Hubs
Solid C’s
Rear:
Jrat 69 Third
3/8 DOM tubes
Solid Spindles
RCV 300M shafts
Yukon 4340 flanges
Suspension:
Steering:
PSC Valve
PSC Pump
PSC Remote Res
Brakes:
Wilwood pedal assy.
Tires/Wheels:
Fuel:
Fast fill kit
E2000 pump
Pre/post AN filters
Malory regulator
Misc:
Master kill switch
Odyssey battery
