Rock Crawling Forums
22re No Run, Coolant In Oil.
Reply to thread
Message
<blockquote data-quote="CHOP SHOP" data-source="post: 1552346" data-attributes="member: 17493"><p>Is there a check engine light? Does the light work?</p><p></p><p>You need to do a check for combustion gasses in the coolant.</p><p></p><p></p><p></p><p>If you dont drive enough to burn the oil out, you could still see moisture with a good head gasket.</p></blockquote><p></p>
[QUOTE="CHOP SHOP, post: 1552346, member: 17493"] Is there a check engine light? Does the light work? You need to do a check for combustion gasses in the coolant. If you dont drive enough to burn the oil out, you could still see moisture with a good head gasket. [/QUOTE]
Verification
Post reply
Friday at 3:12 PM
Daves Offroad Supply
Latest: Daves Offroad Supply
Wednesday at 10:52 AM
Vendors
B
Latest: Bebop
Tuesday at 7:19 PM
P
YouTube of the day
Latest: paradisepwoffrd
Monday at 8:21 AM
Cash LeCroy Illness
