Budget YJ
I think I've finally decided to sell my buggy.
Found a TJ I want for a daily driver.
3 seater
350 on pane
350 turbo
203/205 doubler with triple sticks
60f welded 35 inner and outers w/ drive flanges
70r welded w/ Yukon axles
Coilovers
The bad
It has a cracked outer knuckle and broke stub from the Primos comp
I've got the new 10 factory stub but haven't put it in.
It also cracked the tranny case so needs new case.
Tranny still good and works good.
Just needs case.
Can test drive.
$13500 as is
or will fix everything for $15500
3 seater
350 on pane
350 turbo
Coilovers
The bad
Just needs case.
Can test drive.
$13500 as is
Cant wait till you tear that razor to pieces or get tired of it and get you another real buggy. Then again maybe you will let me build your next one. HaHaHa. ;D
