40spline.com
NEVER LIFT!
This could quite possibly be the easiest upgrade for your factory or fully custom 14 Bolt axle. Everyone knows about the legendary strength of the 14 Bolt R&P but we do see quite a bit of factory shafts broken on the trail. Our full float 4340 or 300m shafts and drive flanges are your solution.
-Made in the USA
-Aircraft grade 4340 or 300m
-Your choice of inner spline, anything from stock 14 bolt up to full 40 spline
-40 spline at the hub (compatible with stock 14 bolt spindles)
-4140 black oxide coated, low profile flanges designed to accept factory 14 bolt axle shaft bolts
-Anodized caps with sealing o-rings, low profile
-Heat treated, polished, and shot peened for better fatigue life
-Profiled
-Involute splines
-Ships in 2 weeks or less
-Set includes shafts, flanges, caps, o-rings, and shaft retaining rings
-Gun drilling option available (300m only)
4340 Set - $899 FREE SHIPPING continental US
300m Set - $1249 FREE SHIPPING continental US
Web store is up and running! 40spline.com
We also have flanges to fit Dana 60/70/80 hubs. If you prefer to run unit bearings or just need shafts, hit us up for a quote on just a set of floater shafts. Questions, shoot us a PM or e-mail [email protected]
-Made in the USA
-Profiled
-Involute splines
