redneckgizmo
Active Member
- Joined
- Feb 29, 2012
- Messages
- 27
I'm going a differnt route and have these parts for sale here's the parts list with prices all part numbers are summit racing numbers. May trade on antique/rat rod/ hot rod ford car or truck or maybe another crawler. Call or txt 931-244-4701
Anderson ford motorsports pms4
programmer new $1,050 used $600
Efi mass air harness and a9p Ecu $300
Trickflo track heat ported and polished intake $450
C&l mass air meter with new sensor $100
75mm throttle body with new tps sensor sum part#tfs-24575 $150 new $100 used
K&n cone filter & piping $30
Summit distributor #sum-850411 $200 new $150 used
Long tube headers w new O2 sensors $100
42lb injectors sum# sum-240042 $339.95 new $225 used
24lb injectors $100
10"x15" weld draglite's w/ 75% tread drag radials mounted (don't remember the brand of tire but can look if interested or will update post later) 4 lug $325
Torque box upgrade kit (will get part number and price new in box)
Full subframe connectors (new in box will get more info)
Aluminum racing radiator with dual electric fan setup and aluminum fan shroud $200
347 stroker complete I will not part the stroker out unless I sell the short block 1st and can price all parts individually if needed I'll take $5k for the long block with all the parts listed below. I have well over $7k invested and no more than 1,000 miles on all of it.
List of parts with the new prices and part numbers where available.
DSS racing level 20 Cnc race prepped pro bullet short block new $3624
Trickflo 170cc twisted wedge heads polished and ported I gave $1,000 for them just outta the machine shop them had them polished and ported
And flowed. They flowed 220 intake and 200 exhaust
Lunatti voodoo cam #20350712 $305
Hyd Roller lifters #tfs-2140000-16 $120
Pushrods #pro-66423c $90
Scorpion 1.6 rocker rollers #scc-scp1017bl $222.95
Timing set #tfs-51478520 $71
Headbolts #arp-154-3705 $96
Balancer #p1o-872032 $200
Under drive pullys #asp-824128 $100
Flywheel #fms-m-6375-a302b $230
Clutch #zzz-f3-48 $286
Trickflo valve covers #tfs-51411802 $130
Canton oil pan $268
Plus high volume oil pump, water pump & new bolts, new timing cover and new bolts, harmonic balancer bolts new, new intake bolts. I'm sure there's more parts I purchased. I put everything new bolts and all when I built it.
24lb injectors $100
Canton oil pan $268
