jeff150
Posting for friend. Lots of good parts in this buggy as it was originally built as a dual purpose Ultra 4 and trail riding buggy. It rides and handles great whether going fast or bouncing up the rocks. Hulk wrap was put on for his daughter who is a huge fan but it is removable. Rear seat is tight but doable for two adults. works well for kids.
Asking price is $24,000 Call or text Shane @ 256-503-3179 Buggy located in Hazel Green, AL
Specs:
6.0 Chevy from a 2006 Silverado (LQ4) 89000 miles
Computer tuned by LT1swap.com
4l80E 2-wheel drive trans out of the same 2006 Chevy
Winters cable shifter
205 divorced transfer case
1410 U-Joints in the driveshafts
Chevy D60 Front Yukon 4340 Shafts 4.10 gears
35 spline outers
14b FF rear 4.10 gears Disc Brake swap
Ruffstuff pinion guard
Ruffstuff diff covers
Trail gear double ended ram
Trail Gear orbital
PSC wheel with quick disconnect
PSC column
Artec front truss and ram mount
Artec steering arms, connect to the factory arms for a stronger knuckle
ARP studs for the arms
Ruffstuff ¾ x7/8 steering heims
RPM off road heavy duty 35 spline drive flanges
Like new 42" TSLs on recentered H1 beadlocks
Chassis built by M4 fab 1.75"x.120"
2x2x.250" Subframe
3/8" ruffstuff tabs at axles and frame
E2000 fuel pump, with spare
Double triangulated 4-links front and rear
Profender 2" remote res coilovers for coil carriers in front (no valving)
Profender 2.5" triple bypass shocks in front
Profender 3" travel 2.0 bump stops in front
Profender 2.5" Coilovers in rear
Corbeau Baja SS front
Corbeau Baja Bench rear seat 42"
Derale Trans cooler with 10" fan
Oil and Power steering coolers
Dual pass aluminum radiator
Autometer Phantom 2-5/8" gauges (water temp, trans temp, oil pressure)
Eagle 500C GPS
22 Gallon Summit fuel cell, Steel with plastic bladder
Remote fuel fill
Amber, red and blue lights, including brake light
PRP 5- point harnesses in front
PRP 4- points in the rear (seat belt style so the kids can buckle themselves in)
Custom window nets
Engo 9000lbs winch with Synthetic line
10" LED flood pattern light bar
115" wheelbase, 18" belly clearance, 76" overall height
Specs:
35 spline outers
Trail Gear orbital
PSC column
2x2x.250" Subframe
Eagle 500C GPS
Remote fuel fill
Custom window nets
