76nick
- Joined
- May 13, 2010
- Messages
- 269
- Reaction score
- 1
S10 blazer cab and frame cut off behind seat and channeled back
Sbc 350 bored .30 .292 comp cam
Comp lifters, 300 horse heads, lunati crank rods pistons, $4500 build by Talladega Speed shop around 450 hp mounted solid
Runs on propane (only 1 tank) impco 425.. mixer mounted under hood
Th 350 one ride on rebuild B&M shifter, new upgraded pump,new upgraded sprag, all new red racing cluthes and plates, b&m stage 2 shift kit, boss hog torque converter 1200 rpm stall
Mounts with factory style cross member with added support to tcase and tcase has brackets that bolt to frame
passenger drop np205 change it to fixed out put on rear with 1350 joint changed front to 32 spline out put 1350?....1410 joints at the axles
D.O.M. drive shaft with course slip spline yokes
Rockwells have been shaved and Mohawked and drain plugs has boot gaurds, after market chromo u joint style in front stock drive flanges
S10 pinion brakes on front for clearance in front of axle
Half-ton chevy pinion brakes on rear in front of axle
Single ended 10" stroke tractor supply ram mounted behind axle
44"x16 tsl grooved 90% tread front
44"x 16 cut boggers 80% tread rear
16" solid 32 bolt beadlocks
4 link rear with coil springs.with retainers and limit chains. Links are round tubing inside square tubing for bracing. (One is slightly bent)
1 1/4 hiems at lowers on axle bushings at frame
1" hiems on uppers at axle
Leaf spring front off stock half ton chevy with 12" travel shocks
4 seater front racing seats with 5 point harness
Rear bench with 4 point harness
2 military storage bins in rear
Center console military storage box
Transmission cooler with fan on toggle switch..
Headlights
Tail lights
Rear lights on toggle switch
Front bumper with stinger and winch plate
Big a$$ aluminum radiator with Taurus 2 speed fan high side was blowing fuses so set to lower speed
Open headers
I love this blazer, fun to drive gets a lot of attention, so easy to drive I let my girlfriend drive up the bad at MMORV first time ever driving it and has never drove on rocks in anything..
Got my eyes on a buddy's buggy but will look at other trades..
$13,000 obo can deliver or meet somewhere reasonable or deliver all the way for a price..
Nick Abram
256-794-3823
Alexander City, Al 35010
Sent from my SM-N900V using Tapatalk
Headlights
Tail lights
Open headers
Nick Abram
256-794-3823
