Sold/Expired 44' Pace American Pursuit Trailer, 6" Lift
Indy Will
Burlington, NC
It's a big trailer, but it's easier to get around than my 28' bumper pull trailer. It's been to every hard to reach offroad park and race there is and never had any problems.
It's 44 ft. long from tongue to the back door. And nothing says you're a winner like a checkered flag wave across the side of your trailer, right?:flipoff2: I just haven't tackled trying to take the vinyl off yet.
3 5000lbs. torsion axles with a trailer weight rating of 15,000lbs. Brakes on every axle.
6" lift. The lift could be removed and the whole thing lowered back down in just a few hours if you wanted to. The factory bracketry is all still there...just take out the lift block...
235/80/16 Michilen Load Range E tires. All brand new within the last 2 years. 2 spares on the back gate.
Basic toilet and shower.
30 gallon black water tank and 30 gallon grey water storage.
25 gallon fresh water tank and a 12 volt pump with internal pressure switch. It'll hold 10 more gallons of water in the hot water heater.
A 10 gallon hot water heater will have a warm shower ready in 10 minutes. Also pictured is the 110volt breaker box. There are receptacles above the counter and 3 outlets down the side of trailer on the outside. It has 12 volt and 110 volt lights.
Here's the 12 volt fuse system. It has two batteries on board which seem to power the whole thing for a couple days between generator or truck hookup charges. There's also two roof vent fans.
Upper deck lounge. There's a window on each side with cigarette lighter outlets in the corner. There's also a T.V. antenna to entertain guests.
Cabinets with the sink and the A/C is in the front. The lower cabinets house the water heater and freshwater tank along with storage. The upper ones are just more storage.
Front storage behind the tongue.
There's a divider flap that is nice to close up on the cold nights depending on the size of the heater you want to run.
Plenty of length for two rigs and full width rigs fit just fine. Vinyl checker board floor. It's a bit beat up at this point. There's a couple spots where the floor has been torn from various rig recovery efforts...
It has a few little cosmetic damages including what's pictured here and the passenger side fender scraped a K rail a few years ago.
$10,500
In Burlington, NC
Will at 336.693.4003. Text for fastest response.
I thought I was the only one who put lift kits on race car trailers! Makes life so much easier not ripping off the rear end by dragging it, especially if you have a 4x4. definitely the best upgrade on any trailer over 30 feet. GLWS.
