Sold/Expired **4WS Single Seat Buggy on Reds ** Built & turbo'd 4.3 v6
zayne2427
There's only one way to find out
Cullman, Al
Located in cullman al 35055
256-347-2508 call or text anytime
Will consider ALL trades with cash
It is Single Seat Buggy
Front and rear steer HP dana 60's
Built chevy 4.3 with comp cam and Turbo T3/T4 Hybrid on Propane
Turbo 350 Trans
Toyota T case 4.7 gears Bobby Long 23 Spline rear output shaft
16" Fox Coilovers front and rear
Full Hydro Steer Front and Rear
High Steer Arms Front/Rear
Dana 60 410 Gears wt Spools 35 Spline Axles with Solid Drive Flanges
On board Welder
2 Propane Tanks
Rock Lights Front, Rear and Sides
8000 pound winch front
2000 pound winch rear
New axle seals in the rear and All bearing have been repacked and all hubs greased.
I am about 6'2 210 lbs for size reference.
The tsl wheels and tires in some of the pics are sold.
It now has brand new 39" BfG red label Krawlers on MRW extreme duty beadlocks
01/2014
Engine is built, installed, and ready to ride
Spent $2k on a bottom up rebuild
main bearings, cam bearings, timing set, oil pump, freeze plugs, rings, rod bearings
Stainless steel valves, valve springs
Exhaust valves
Marine grade head gasket
Hypereutectic pistons
Heads surfaced
Valves grind
Block bored .040
Polished crankshaft
ARP Head studs
Buying a new house so I'm going to price this a few different ways
**Current Toyota transfer case broke a gear and is pulled out of the buggy. It needs a new set of gears and tcase can be reinstalled. Will take $14000 Cash like it sits minus wheels and tires. The gears from Trail-gear.com are $576.45 or you can buy the whole case ready to bolt in for $891.45. and it would be ready to ride with your wheels and tires
or
- I can sell a 3.8 Atlas with the buggy. I have all the tabs and mounts to install. I will sell the with the buggy for $1800
or
-I have a set of MRW Extreme duty headlock and 39" BFG Krawlers (Red Labels) i will let go with the buggy for $3000.
Most recent pic
Thanks
Re: **4 wheel Steer Turbo'd Single seat Buggy**
Got to see this rig do work!
Love the whistle :woot:
Just rode w/ this buggy this weekend, sounds awesome and works great!
Buggy looks awesome! What's wheelbase and belly height? :woot:
It is a blast to drive. Wheelbase is 115. Belly height is right over 22 inches with 6 psi in tires
wow....you got rid of the wheels and tires......wonder what caused you to do that.......
Slick ass rocks of hale mtn....i told you i would. Tired of the yota showing me up. Did u get any good videos or pics
Re: **4 wheel Steer Turbo'd Single seat Buggy** New Price
This buggy works great, met Zayne and rode with him for the first time @ Tracy City. Whoever gets this will not be disappointed for sure. Very compact and neat.
Thanks man its a fun ride for sure. Its a blast to drive. Ready to get into a small 2-3 seater where my lil boy can ride with me.
Ttt for cash offers
Thanks man. Hale mtn was a blast.
Will consider all trades like it sits.
Price will be going up at the end of the week. Should be sitting on 39 BFG Red Labels soon!
Still for sale?
