Sold/Expired 7075 Aluminum Links Bars
RocksolidPerformance
Active Member
Grand Rapids Michigan
RockSolid Performance 7075 Aluminum links
Tired of bending your steel tube links? Trying to shave some weight off your rig? These RSP 7075 Aluminum links will hold up to a serious pounding. Guys have been running this style link for a long time at KOH and more. We are now offering on our website Aluminum links available in 4 tap sizes and 4 bar sizes. We offer 2 ¼ Diameter bar to for those looking to go big. Check out our web site to purchase. You can also use these for Tie rods and drag links
http://www.rocksolidperformance.com/7075-aluminum-links/
Tap sizes available will be
3/4-16 LH or RH
1"-14 LH or RH
7/8-14 LH or RH
1 1/4"-12 LH or RH
Price includes a 2' section drilled and tapped to your specs.
$90 1.5" diameter,2' long. Add $1.75 per inch for longer link
$95 1.75" diameter,2' long. Add $2.00 per inch for longer link
$105 2.0" diameter,2' long. Add $2.50 per inch for longer link
$120 2.25" diameter,2' long. Add $3.00 per inch for longer link
Any one lookin for some heavy duty 7075 aluminum Links???? These are heavy duty and will not end up bent like some of the 6061 Aluminum links out there!!!! Place your order today and get these pretty things on your rig before the wheelin season takes off again!!!!
Got Bent Lower Links????? Want them to stop bending???? Replace them with these 7075 Aluminum Links. These are the baddest links out there!!!!! Get some for you rig today. These work Great For Tie Rod and Drag Links Also.
Your steel Link bars bent or just want to upgrade before they do? Get these 7075 aluminum link bars. These things are indestructible. All Orders placed by 9/30/2013 Will get free Wrench flats and custom name engraving!!!!!!! Call to order 616-696-8114
