Sold/Expired '74 FJ40 Chassis- Part Out!
Neal3000
2
Temple, GA
For Sale- 1974 FJ40 with vin and ***le, full 2" DOM cage tied into the frame, front and backhalfed approx 3' on each end. Removable doorbars/aluminum doorskins. Seat mounts setup for Corbeau XP's. Mounts for sbc/th400/Atlas. 4-linked front and rear (lowers are 5 degrees at ride height with slightly converging uppers on the back, parrallel on the front) on 1ton axles. Full coverage flat skidplate. Rear radiator,(19x26 dual pass AL.with Taurus fan) Wheelbase is 114", shockmounts for 16" Fox coilovers in front and 16" fox coilovers and bypass shocks in the rear. 2" fox logo bumpcans all around. Setup for 18" bellypan height with 7" of uptravel in the front 9" in the back. It has full hydro steering with Danfoss orbital 2.7 turns lock-to-lock. Removable steering wheel, TK1 racing swaybars front and rear. 2x RedneckLights 20" led lightbars with rollover protection. Led tail/brakelights. Brake lines are intact, has FzJ80 mastercylinder. Aluminum dash(kept my switch and guage panels so i made new blank panels for the dash). center console, and rear firewall. It's got 7075 aluminum links, 2" lowers with 7/8 heims, 1.75 uppers with 3/4 heims. Front and rear links are the same lengths.
Front Axle- '97 Ford hi-pinion Dana60, built 1.5 years ago with all new bearings, seals, brakes, wheelstuds, and balljoints. retubbed by HeMan Machine into passenger drop and shortened the longside by 3" (uses a snowfighter longside). 67" wms to wms. 4.10 gears, Yukon grizzly locker, Factory10 axleshafts, Yukon superjoints, poly perf flanges, trailgear ram, lubelocker diff gasket, Bluetorch Diff cover, truss system, and link brackets. Includes spare factory inner-axles with spicer lifetime joints.
Rear Axle- C&C 14 bolt, 63" wm-wms, built 3 years ago with all new bearings, seals wheelstuds and brakes. 4.10 gears, G2 mini-spool, bluetorch truss, pinion guard, link brackets, and brake brackets, Barnes4x4 13 bolt diff cover. GM 3/4 ton disk brakes.
Axles and Hydro stuff- going to Kel
Chassis- $1100
Links- $600
Lightbars- $160 each
Radiator & fan- $160
Master Cylinder & booster- $160
Swaybars- front $175, rear $225
Located in Temple, GA
Pm me for pics of anything in particular
Full pic Album here- http://s281.photobucket.com/user/ndh1971/library/74FJ40?sort=3&page=1
Pics of it when it was running-
http://s281.photobucket.com/user/ndh1971/library/project%20mayhem?sort=3&page=1
Re: '74 FJ40 Chassis, Linked on Tons
I have a hard time reading the description with your avatar doin it's thing ;D
Those axles and steering components are missing their seats and coil overs :****:
GLWS.....I really dig the color too
I really cant read or comprehend anything but that avatar! BUMP fer ya :dblthumb:
I believe the right person could throw an LS/400/Atlas, wheels/tires and shocks and be in a badass rig for less than 20k. :dblthumb:
and seats
muddinmetal said:
and seats
Couple of lawn chairs and done!
Bump for ya Neal - Sweet rig, and worked nice when it was together.
Sent from my iPad using Tapatalk
good deal for someone!
Are you the guy that I bought a cammed 6.0 LQ9 from a while back? I recognize that backyard haha
Yep that was me, did you get the engine/buggy going yet?
Its not going yet (i know....its taken for ****in ever :wtflol: ) but its close!
I got it all together for the most part, just needs some final fab and then blown apart for weld/paint....then its time to wire and plumb.
I would like to have it painted/welded/and back together by the end of the year. We will see though....
