Steele3
==============SOLD===============
I have a 76 Jeep CJ5 with NO ***LE I have decided to part out.
It was running but ICM is out i guess no fire to starter, gas tank leaks, brakes not hooked up (master cyl. is bad, and pass. side caliper is missing, rear brakes on pass ride missing), no seats but have frames. Its sprung over. Sheet metal is good except for a couple spots on body.
Located in Lutts, TN 38471 north of the Florence/Shoals area
post/pm
call/txt - 931-3O6.158o
Has a running but smoking 258 I-6, 4-speed T176, and D20 --- $350 for all 3.
Tub is in ok shape, rust hole in drivers side where jeep logo is, hole in rear under tail light. Front cap is in good shape. Good windshild frame and glass. frame has some rusted through spots, if cage stays in it --- $550 you get everything from the springs up minus the motor/trans/tcase
D30 disk front missing pass side caliper n bracket/ D20 rear missing pass side wheel cylinder, shoes, and springs, sprung over. with 33" at's on 15x8 rims --- $250
Cage is bolted in and bolts are froze. can torch the bolts if you want the cage ---- $200
post/pm
