Sold/Expired 78/79 HP60 & 14 Bolt - 4.88s, ARB's, Chromos
4sd air95
Member
Front Axle
78/79 Ford Dana 60
4.88 Gears recently rebuilt
ARB with New Seal Housing and O-rings
New Bulkhead Fitting
Chromoly Shafts with Spicer non-greasable joints
ECGS 35 Spline Flanges
Dedenber Knuckles (stock location arm is cut)
High Steer Two Hole Arms
Shave kit with bent steel cover
1350 Yoke
Coil Brackets of some unknown origin
Rear Axle
14 Bolt 66.5 WMS
4.88 Gears
ARB
Shave Kit with bent steel cover
1350 u-bolt yoke
Disc Brake Conversion
Stock Shafts
Pinion Guard
Leaf spring and shock brackets.
$5000 plus $250 shipping anywhere in country. Can strip the axles bare if necessary. Pics coming shortly. Baby on the way and these need to go. Located in Durham, NC.
