B
BeagleBones
Guest
I bought the bike early last Summer. It was a complete basket case. 45 minutes of work just to get a roller to load on the truck.
New tires
New wheel bearings
New chain
New grips (left side needs to be re-glued I effed that side up some how and it doesn't stick as it should)
Tank cleaned and Kreme'd
Made a rear tail section that includes a LED lamp
Boiled and rebuilt the carbs (they will need to be mounted/synced)
Needs the carbs synced, petcock and a small bit of fuel line down to the carbs, foam/cover seat pan if your candy a** needs, battery, and a front brake if you like.
I was going to finish it up and sale but I've got two other projects going now so I need $ or parts.
Building a Samurai buggy so I need buggy parts ie. Toyota axles, coil overs or air shocks, motor, transfer case, tubing bender....... You get the idea.
Thanks
Mike
615.512.0121
Nashville TN
New tires
New wheel bearings
New chain
Thanks
Mike
615.512.0121
Nashville TN
