Nov. 1982 Toyota Hilux. I have owned it for about 4 years. It was my daily driver for about 6 months.
I put about 5,000 miles on truck with flawless performance. Its been garaged for last 2 years.
( with exception of one problem, caused by me. I had pinched wiring harness with installing seats.)
Price: 10,500
The only bad items, or items left on my repair list are
1. rear elocker motor not working. (Takes 2 minutes to remove 3 nuts, pull motor, slide rodre install motor and rear is locked.) But motor needs repaired.
2. If the new owner wanted to wheel it hard ( I did not want to destroy it) it would need the T-100 oil pan swap. T.G. Sells kit for about $250.00.
3. The paint quality up close is in poor condition, could use new paint.
The list below was compiled by previous owner, with some changes by me added.
~Nov. 1982 Toyota Hilux
~2004 Toyota Tacoma 2RZ with 34,900 miles on the clock (includes ***le from Tacoma motor)
~Marlin Crawler HD 1200 Clutch and Flywheel
~Toyota Fiberglass Bed(Full, Double wall, From Toyota Fiberglass in BC, New body Bushings and Stainless Steel Hardware
~Tacoma A/C, New TOYOTA Condenser, New A/C Dryer, A/C Dye Injected in case of leak
~80 Series Land Cruiser Master Cylinder
~KenWood Speakers, New radio w/usb port
~Optima Red Top
~33” tires, 95% tread
~Warn M8000 with AmSteel Blue Synthetic Rope, Controls mounted in Engine Bay
~30 Spline Chromoly Longfield Axles
~Chromoly Longfield Hub Gears
~Marlin Crawler HD inner axle seal
~80series High Pinion E-Locker
~12 Volt Guy E-Locker Switches
~W56-E 5 Speed Transmission
~Marlin Crawler Dual Ultimate Crawler Box (Built by Marlin) 2.28/4.7 W/Synthetic gear oil
~Marlin Crawler VSS
~Tom Woods Drive Shaft
~Tacoma Rear axle
~Tacoma E-locker 4.11
~Marlin Crawler U-Bolt/ Spring Plates
~Tacoma Rear springs w/ added leafs, MC zinc Plated Shackles
~Fully boxed and Sealed Frame with 3/16 Steel, Lengthened MC spring hangers
~Marlin Crawler Rear Bumper
~DOM .120 Sliders
~Bud Built T-Case Crossmember/ Slider
~.188 DOM Front Drive Shaft
~New TOYOTA Rear Wheel Cylinders, Pads, Drums and Hardware
~Braided Steel Brake Lines
~Toyota Land Cruiser Front Disc Brakes
~4Runner Calipers, TOYOTA Brake pads
~Tacoma Gauges
~All New TOYOTA lens(Turn Signal, Front and Rear Markers)
~Early Style Grill,Buckets and Lights
~Early Style Steering Wheel
~Hella H4 7" Glass Headlights
~High Clearance Front bumper
~New TOYOTA Denso Heated Air/Fuel Sensor
~Mobil 1 Fully Synthetic 5w-30 changed every 4-5K
~Toyota Red Coolant, Stainless Steel Over Flow Tank
~New Radiator Barn Radiator
~Tacoma Gas Pedal
~New Toyota Belts, Hoses
~6 Bolt Engine Mount ( No more torn rubber engine mounts)
~Newer EFI Gas tank and Fuel Pump
~Stainless Steel Fasteners Thru 95% of the Vehicle, New Zinc Plated Fasteners in Structural Locations
~ New Carpet W/ 2 layers of sound proofing
Leather seats, from back seat of Dodge durango, center console raises for 3rd seat/ 3- seatbelts
rear aluminum tool box added, modified to fit.
~Handles highway speeds easily, Fast light rig...
~Receipts for just about everything
Located in Tampa Fl, Greg 813-918-6618
Price: 10,500
~Optima Red Top
~Marlin Crawler VSS
~Tacoma Rear axle
~DOM .120 Sliders
~Tacoma Gauges
~Tacoma Gas Pedal
drool drool drool
