Sold/Expired 83 TOYOTA CRAWLER PRICED TO SALE******SOLD******
1stgenrookie
Member
Got my 83 yota crawler up for sale, this was my first build and has been a very dependable trail rig for the past few years... only reason for selling is because it gets ran maYbe 1-2 times a year and needs a new owner that can use it more.. now for the list of stuff:
-83 cab and chase with full exo cage(1.50) with custom air brushed hood
INTERIOR
-pretty much factory interior with great sound system, CB radio, OOGA horn,battery disconnect switch, 4 point harnesses, and most has been sprayed with Duplicolor bed armor
DRIVE TRAIN
-22r on propane with 4 extra tanks
-new head gasket w/ valve job
-new timing chain and water pump
-new ps pump and all ps hoses
-long tube header
TRANS & T-CASES
-5spd with new clutch kit
-new slave cyl and clutch master cyl
-dual cases with Inch Worm adaptor and stock gears in both
-Front Range cross member
-1/4" wall square drive lines
-1/4" thick skid plate
FRONT AXLE
-83 AXLE with longfields with hub gears
-529 gears whith lockrite locker
-TG ubolt flip kit
-TG trusses, ball gussets and diff gaurd
-Marlin Crawler high steer kit
-all new bearings and seals from TG
-3" wheel spacers
REAR AXLE
-86 IFS axle with stock shafts
-529 gears with full spool
-1.5'' wheel spacers
SUSPENSION
-front is custom packed factory 1st gen leaf springs with 12'' bilstien shocks and TG shock hoops
-rear is 63'' chevy leaf springs with 14'' bilstien shocks
WHEELS AND TIRES
-New 37/14.50/16 Maxxis Creepy Crawlers with bout 6 rides on them
-new 16x8 D-window steel wheels a with custom weld on 24 bolt beadlocks
Im sure im forgetting something so you can call or txt or pm for more info.. the truck is located in Granite Falls NC..... Not really looking to trade but would consider trading for a cool rat rod or polaris rzr (with maybe some boot on my end)... My asking price is $5500 CONTACT ME @ 828-638-0672
Re: 83 TOYOTA CRAWLER PRICED TO SALE
Price bump!!!! $4800 or open to any trade
:spin: interested in a 2001 zr2 blazer sas with Dana 44hp ford 9" discs all the way around spooled rear 488 gears stock 4.3 auto and push button case coil spring front with radius arms leaf rear 38.5 tsls the fronts are worn rears are 70% all power a/c heat sun roof. May add cash or possibly a sweet spikes tactical ar15. Let me know 850 6424030 thanks Ben.
Going to pass on the trade but thanks for the offer..
