88 YJ 4 cyl manual to power steering
xraidedj
I poop in Pepsi cans
Wenatchee
88 YJ 4 cyl manual to power steering conversion questions. I have xj, yj power steering boxes laying around and a 99 xj pump, but......I don't have the bracket for the 4cyl and its not serpentine belt. Can someone take a pick of their stock 4cyl setup and tell me what I need to do to make this work. '
How do I use a power steering box in a manual setup without a pump for the mean time. Connect high and low pressure together so I can fill with fluid? The stock box is destroyed and so I need to at least get this going some how. Figured I would just convert it beings I have to pull the box anyway.
Any help would be greatly appreciated.
I beleave the steering box brackets are the same power or not. You will need the lines pump, pump brackets belts. N so on.
