highrolrcustoms
1989 Mustang GT
MOTOR SPECS:
Fresh 347 Stroker
Eagle Crank
Eagle Rods
World Products SR Heads with 202/160 Manley Valves, screw in studs, guide plates
Anderson Motorsports Cam
1.6 Aluminum Roller Rockers
Holley System Max intake
80mm Accufab throttle body
83mm Pro-Flo Mass Air meter
36lb injectors
Accufab adjustable fuel pressure regulator
Sheetmetal valve covers
Canton 7qt oil pan
Underdrive crank pulley
TRANSMISSION:
Tremec 3550
Hurst short throw shifter
stage 3 clutch
COOLING
Aluminum radiator
Electric fan
SUSPENSION:
Tubular K member
Tubular A-arms
Adjustable front coilovers
UPR adjustable camber/caster plates
Subframe connectors
Lakewood rear drag shocks
Southside rear lower control arms
Adjustable rear upper control arms
REAR AXLE
8.8
410 gears
spool
31 spline axles with extended studs
c-clip eliminators
Trick Flow diff cover w/bearing cap supports
WHEELS
Weld Pro Stars 15x8 rear, 15x3 front
5 lug converison
EXHAUST
3" Long tube headers
3" tubing
Magnaflow mufflers with dumps
SAFETY
Wild Rides 6 point roll cage
drivers 5 point harness
ELECTRICAL
MSD PRO billet distributor
MSD 6AL box
MSD coil
Auto meter gauges
EXTERIOR
4" cowl hood
saleen wing
Car is in real good shape for the year. its an awesome street car. the motor beats the ground!!!! Interior is in great condition. seats show no wear. Im looking to trade for a crawler/buggy or a rzr. looking to get back in the offroading scene again.
$10,000 trade value. $8500 CASH
423-930-5402 text or email is best.
MOTOR SPECS:
Fresh 347 Stroker
Eagle Crank
Eagle Rods
36lb injectors
Canton 7qt oil pan
TRANSMISSION:
Tremec 3550
stage 3 clutch
COOLING
Aluminum radiator
Electric fan
SUSPENSION:
Tubular K member
Tubular A-arms
Subframe connectors
REAR AXLE
8.8
410 gears
spool
c-clip eliminators
WHEELS
5 lug converison
EXHAUST
3" tubing
SAFETY
ELECTRICAL
MSD 6AL box
MSD coil
Auto meter gauges
EXTERIOR
4" cowl hood
saleen wing
