Sold/Expired '91 Wrangler-1 ton, V8, 42s $8,000 obo
Craig E
Jeep will be at HPO this weekend, the 18th for the night ride. Come look at it.
1991 Jeep Wrangler
117" wheelbase
The cowl is 55" tall with street pressure in the tires. The belly height is right at 20" inches.
Powertrain
TBI 350
SM465
NP205 twin stick, 32-spline Ford front output
Aluminum radiator w/ Taurus fan
Front axle
Chevrolet D60 front 5.13 gears, welded, hi-steer, GLO diff cover, 30 spline outers and lockout hubs
Rear axle
Old school Eaton with 5.14 gears, welded, disc brakes
Front suspension
4-link
Fox 2.0 16" air shocks
Rear suspension
Toyota mini-truck leafs , recessed into the frame so they won't get hung up
Bilstein shocks
hydro steering
Tires
42x17" Iroks w/ 80% tread
Wheels
Cragar D-windows with 36 bolt weld-on beadlocks
Driveshafts
All 1350 joints
Skidplate
Flat ¼" plate with reinforcements. Small bump for the transfer case
Cage
1 ¾" HREW welded directly to the boatsides at four points. The rear of the cage is sandwich-mounted with the tub.
Seats/harnesses
Corbeau Baja SS w/ G-Force 4 point harnesses. I have the crotch straps if you want to install them.
The seats are mounted to the cage.
Fuel Tank
15 gal. aluminum
The winch is staying with me, but the holes and fairlead mount will be ready for your winch.
Located in Tupelo, MS, but I can deliver if within a couple hundred miles or meet halfway within that distance.
$8,000 obo
Re: '91 Wrangler- FRESH BUILD
asdf
asdf
asdf
I have left some details out, but I can fill in the gaps if you have questions.
Message me here or call/text 662-346-1476.
Re: '91 Wrangler- FRESH BUILD 1 ton, V8, 42s
Bump. Motivated to sell...
Price drop.
$11,000 obo
Make me an offer.
Re: '91 Wrangler- FRESH BUILD 1 ton, V8, 42s Price Drop
OBO...also willing to trade.
$10,500 obo...ready to sell
Re: NEW PRICE '91 Wrangler- FRESH BUILD 1 ton, V8, 42s
Willing to trade for a streetable TJ with a 4.0, auto, and 35s...
That's right, old school cool.
Had one in my CJ7 for years. Picked it up cheap from a guy a Knoxville after a fresh going through of the axle and came with everything needed for a disk brake swap. I loved that axle!
Bump...needs a new home.
Bump...now has a new ignition module and coil.
Re: Reduced Again- '91 Wrangler- FRESH BUILD 1 ton, V8, 42s
New lower price- $9,900 come and get it or trade for a TJ on 35s.
Forgot to say in the last post that I updated the description. Now all u-joints are 1350s.
I'm ready to sell this thing. It works great, but I'm just downsizing for a little while.
I honestly can't believe this thing hasn't sold yet. If I had the coin I'd be very interested in this setup.
Thanks ridered. Someone needs this Jeep! Solid, simple, and very low. The cowl height of this Jeep is the same as my buddy's CJ that has a 4" spring under and 35s. My Jeep has 42s. It's very stable.
I've had several conversations with interested buyers, but I don't have any cash in hand yet. I'm ready to move to the next project, so come make me an offer I can't refuse. I'll load up and meet you halfway.
Craig
