red94yj
Selling a 1995 Toyota Corolla 1.6L, 5 speed manual trans. Manual windows. Car has 226k on it.
Car has been well kept but does have issues.
Timing belt was last replaced at 145k. Water pump was just replaced at 225k. Engine oil and filter were changed regularly at 5-7k intervals. Last oil change was at 223k.
Ac works great as well as the heat.
Car runs and drives okay. Clutch pedal sensor sometimes is finicky, but it hasn’t let me down. Throw out bearing can be noisy during warmup at idle with clutch out. Car burns oil, probably about half a quart every 500 miles or so. I check it every other day of driving it. 4th gear is pretty useless. You can cruise with it at around 10% throttle but if you push it, it will pop out. 5th gear can be tricky to get into sometimes. 5th can also randomly have a whine to it The right front tire has a little movement to it due to a bad rack and pinion bushings. Still steers fine, just feels sloppy. Tires are in decent shape. Exhaust manifold has a crack. Windshield has a crack.
Radio works as well as tape player. Interior lights all work. Gauges work. All headlights and tail lights, and blinkers work. AC and heat work.
Interior is worn, headliner is coming apart, seats have stains. Come with 2 keys, one for ignition and one for doors.
I’ve tried to include everything I can remember. I don’t drive it much anymore, but don’t want it sitting up much longer.
Little car will get you from point A to point B. ***le is clean and clear, in my name. Does come with a brand new cloyes timing belt ready to install around the 245k point.
Price $1,000.00
Car is located in Trussville/Argo
Can meet most afternoon weekdays and anytime on the weekends.
Call or text Brad 205 332 2782
Price $1,000.00
