Sold/Expired 97 TJ, 1 Tons, Gears, Lockers, 39'S
bigjon9856
Member
97 Wrangler TJ
4 cyl 92k
New Battery
New serpentine belt
New Ignition Coil
New Crank sensor
New slave cylinder
New Lower radiatio hose
5 Speed Trans
Np231 Transfercase
Novak 2 Wheel Low kit
SYE and HD rear drive shaft
HD Front drive shaft
Front Axle
78 Ford Dana 60
4.88 Gears
Lincoln Locker
Warn Hubs
HD 1/2" thick diff cover
HD High Steer arms
HD D.O.M. Tubing sterring
All Heim Joints
Hydrolic Assist with HD Ram
Rear Axle
14 Bolt
4.88 Gears
Lincoln Locker
Disc Brakes
HD 1/2" Thick Diff Cover
Pinion Guard
Front is streched and Long arm 4 link kit all custom, with Bump stops
Nitrgen shocks
Rear is streched and leaf springs from a cherokee with a add-a-leaf spring.
Rear Track bar
Nitrogen shocks
39" Super Swamper Iroks 90% tread
Custom recentered h1 beadlock wheels
HD custom winch bumpers Front and Rear
Rocker guards
Comp cut rear
fuel tank mounted in rear of the jeep
Have the back seat if wanted
LED tail lights
KC lights up Front
Full Soft top
Half doors with Soft windows
$7800 OBO Have ***le in hand
Any Questions call 205-601-1261
