97 TJ- 302 V8 , C6, NP205, HPD44/ Sterling 10.25 , 37 MTR on H1 Beadlocks - Madison,AL - $8500
95limitedzj
Auburn, AL
1997 Wrangler TJ unknown chassis miles, motor was said to have ~20k on it after swapped into the jeep.
Runs, drives, shifts as it should. Clean KY ***le.
Ford 302 V8, C6, NP205 HP D44 front locked front Sterling 10.25 LSD rear 37" mtr on 24 bolt beadlocks
Details in pictures Asking $8500* obo.
If you are interested or have questions msg me and come see the jeep and we can make a deal. Would also consider trades up and down for 67-72 C10 swb.
Drivetrain and Suspension 9/10
302 ford v8 swap
Edlebrock 4 barrel carb and weiand aluminum intake
Shorty headers and True full dual exhaust
C6 transmission with hurst pro matic shifter
Np205 transfer case, stock tj shifter location
Freshly rebuilt driveshafts front and rear
HD High Pinion Dana 44 front axle 4:10 geared with Lock-Right auto locker
New Milemarker selectable hubs
New Ruffstuff 1 ton steering and tie rod ends
Sterling 10.25" rear axle 4.10 gear LSD
~4" skyjacker suspension lift with fixed length lower control arms and new Rancho RS5000x shocks.
3" body lift
Sway bar quick disconnects in the front
New front track bar
New stainless braided brake lines
37x12.50-16.5 goodyear MTRs ~ 75% tread
24 bolt hummer double beadlock 16.5" wheels
1.5" wheel spacers on all 4 corners
Small rear main oil leak, not worth fixing probably
E-brake cables could use adjustment
Exterior 7/10
New Rampage top with new front door uppers still in the box, and tinted rear windows for spares.
Smittybilt SRC front and rear bumpers
Custom rock sliders with mini boat sides and flat belly skid with bump for transfer case.
Front flat fenders unknown brand
LED tailights
Tailgate tag plate with lights and brake light
Black aluminum fuel door
Previous owner must have plastidipped the jeep poorly at some point and the paint isn't great on the hood and windshield surround. See pictures. They also cut holes in the tub for other tail lights can be seen behind the current lights.
Interior 7/10
Stock tj interior. Heat works. No A/C.
New speakers in dash and soundbar.
New Usb/bluetooth head unit
Autometer gauges in cluster. Speedo needle not attached but odometer still works. Volts/ Gas/ Oil Pressure/ water temp gauges work.
Previous owner drilled holes to mount stuff in the dash, there is no carpet. Seats are in decent shape but not perfect. Steering wheel is worn.
A few more pictures. If you want to see something specific let me know and I'll take more.
