whiskeymakin
located in mid TN 37388
its a 98 tj with a ***le, backhalf with 2x3 tube.
-118ish wheelbase
-5.3 vortec low miles. runs great. advance adapters swap radiator, so there are no cooling issues. brake master cyl upgraded to the dodge truck deal.
-autometer guages
-e8248 fuel pump and corvette filter setup
-all AN fittings and high pressure hose
-built th350 with a large cooler with fan, mounted under the rear of the tub, dirt car type shifter with NO gates for quick shifting
-stak monster 2 speed 3.75 case with 1410 yokes
-4 link setup front and rear with 2.25 7075 al. links and 1.25" heims, tabs are 3/8" material
-chevy 60 front with high steer gusseted arms. 1410 yoke, brand new never ran yukon axles and super joints. eagle machine ram. 4.56 gear. warn drive slugs. trussed. 5000 psi aeroquip hose and fittings, field serviceable
-14 bolt rear. 4.56 gear. 1410 yoke, trussed. disc brakes pinion guard
-limit straps on all four corners
-2.5x16 fox air shocks, tuned pretty good
-2" front air bumps
-currie sway bar
-15"X10" allied HD beadlocks with 44" tn cut tsls
-sniper fab roll cage all tied into the frame correctly
-sniper fab winch bumper with a new warn powerplant 9500 winch
-sniper fab highline fenders with cut down hood
-weather proof rocker switches for the fans and rock lights underneath
-cd player with ipod hookup
-new safari top
-procomp headlights
im sure there are probably a lot of small things im leaving out, best way to reach me is by phone. 931-581-four-294
not interested in trades unless you have a 05^ vette....the wife will hate that hahaha
its a little dirty but cleans up pretty good, its flat black with hammered silver roll cage. heat works too
18000
-118ish wheelbase
-autometer guages
-2" front air bumps
-currie sway bar
-new safari top
-procomp headlights
18000
