Sold/Expired 99 TJ Jeep compete rig .
crawler1
Southern Ill
After meeting a bunch of you guys down at Gray Rock , and having some good conversations , and checking out all the sweet looking tube buggy's I have decided to build me one . But i have to get rid of a few things off my jeep first .. I Just want to see what you thoguht might be a good price for what i'm going to sell , and see if there was any one interested in it .
What is up for sale is a 99 Tj body , aluminum fuel cell , seats , roll cage , and just bunch of other stuff in the pic . The wheel base has been stretched to 103 , 6 inch steel finder flares are welded to the body , and the whole rear of the body is 1/4 plate rolled around it . i do have a ***le for the jeep , and it has working head lights , turn singles , and brake lights . The jeep is licensed in Ill
All i am keeping off of this is the axles , engine transmission , and transfer case , winch , and the gages . pretty much everything else will go .
Im sure there is some little things i for got ..
If you have any question , or any feed back please let me know . Thanks Justin
Or if you are intrested in the whole thing .
The engine has 1900 miles on it , and the transmission , trans case , front and rear axles are new . only 4 trail rides on them .
350 small block
Edelbrock Pro Flo injection
350 th Hughes transmission
atlas 4.3 -1 passengers side drop
rear high pinion Dana 60 rear 4.88 Detroit locker 35 spline mosier axles
front spidertrax 50 deg. turning axle , every thing is spidertrax in it , and in it .
high 9 front center section 4.88 Detroit locker 35 spline
psc full hydro steer double ended ram .
B/M trans cooler with built in fan .
manual brake front / rear seperate master cylinders ,
4 pistion willwood calipers all 4 corners .
25 gallon aluminum fuel cell
Art-Carr standard shifter
full 1/4 steel skid plate under neath
water proof marine radio
auto meter gauges - tach withshift light , digital speed meter , liquid filled oil pressure , liquid filled water temp , and voltage meter
39/18-15 boggers 75 percent left .
15-10 steel bead locks 3 inch back set .
Have hard top and full doors for this along with bikini top .
fully street legal in illinois .
has a cracked windshield , and one dent in the tube next to the window .
Im sure there is somthing i for got to list .
Recipts well over 42000.00 in this
Asking 35000.00 obo.
ill get some more pictures up as soon as i can get them loaded .
