I’m still unsure if I want to sell or not but I’m going to post it. This is THE AFFLICTION BUGGY and has proven itself as one of the toughest buggies out there. It just received lots of new upgrades and is ready to race.
Affliction buggy
427 stroker Dart LSX Next Block
All forged internals
I beam rods
10.5 to 1
Fast 102mm throttle body, intake and fuel rails
Fast 88lb injectors
MS3 Pro harness and ecu
Electric water pump engine mount and in line
A1000 fuel pump
-10an feed and -8an return
PTC Built Reid case th400 pro mod drum, billet internals. All good parts.
Nitrous converter reworked by PTC
TWF Hero case with 3.75/1 gear set
Front axle is 14 bolt 3.73 gear 40/47 spline ouverson aluminum hubs /flanges with 3/4 ton rotors and wilwood calipers WOD Fabricated knuckles all psc steering XR series D.E. Ram 2.75 P Pump
Rear axle is 30 spline 14 bolt 3.73 gear Mark Williams 300m shafts aluminum hubs wilwood rotors and wilwood calipers mark Williams spool
Shocks are triple bypass radflo's tuned by Phil Licciardi
$60,000
Best to call or text 931-209-0693
Affliction buggy
I beam rods
10.5 to 1
Fast 88lb injectors
A1000 fuel pump
$60,000
