zukimaster
Hold my beer and watch this!
Just about got everything ready to do my 4.3 swap, so i would like to sell all my stuff i dont need. the motor, trans, transfercase, the motor is a .40 over flat top 1.3, has hedman header, this engine was completly rebuild in September, but it started smokin a little then at the Shamrock run it got bad, tore it apart and it had the wrong oil rings in it! so, had it rehoned, new ring, bearings, rode it all yesterday at Mountain Side, did great! it has a 40mm harley carb, the trans is a stock 5 speed, I give over 300.00 for the cluth kit, the t-case has a 5.1 low gear, Rocky Road Mega Mount kit. I would like to sell this as a complete setup, between the new motor, harley carb setup, clutch, t-case gear, i have over 2k invested Not including any labour, and i will throw in all the little extra stuff, radiator, clutch cable, fuel regulator for the carb, this is a perfect running setup! goin to leave it in my Zuk so you can hear it run, drive it or whatever, this would be a perfect setup in a 1 seater buggy or anything lightweight. not goin to ship anything! Im in FT. Payne AL my # is 256-996-2862 if you have any questions. 1200.00 takes it all, have all paper work to verify motor work
[attachment deleted by admin]
