Sold/Expired Aluminum Universal Switch Panels from Motobilt
motobilt
"I Build Stuff"
Dothan, AL
7 Hole Aluminum Switch Panel
SKU MB5511
Only $14.99
The Motobilt 7 hole switch panel is laser cut out of 1/8" aluminum. The holes fit your standard rectangular rocker switches commonly used for lights, air compressors, lockers, and many other components.
The 7 hole switch panel's possibilities are only limited by your imagination.
Switches are NOT included.
3 Hole Aluminum Switch Panel
SKU MB5510
Only $8.99
The Motobilt 3 hole switch panel is laser cut out of 1/8" aluminum. The holes fit your standard rectangular rocker switches commonly used for lights, air compressors, lockers, and many other components.
The 3 hole switch panel's possibilities are only limited by your imagination.
Will you be offering the entire switch box and all at any point? :dunno:
ADMINISTRATOR
motobilt said:
I don't know of any plans to right now.
What would you like to see?
Maybe a 4 or 8 switch panel that can either be rollbar mount or flat surface. Ultimately a box that is already pre wired with a screw in connector on the side with a harness to either 4 or 8 utilities would be perfect. Not many companies want to do this for some reason other than Moroso or Joe's. thumb.gif
ADMINISTRATOR
SKU MB5510
Only $8.99
