another damn propane problem
twiztedzuki
vacuum lock, impco model, e and 425 impco mixer on roller 383, WOT it dies and have to reprime it! i have checked for leaks, reg is not freezing, soon as push prime on reg it fires back up? :dunno: i have searchd everywhere cant seem to find a answer
I had the same problem not long ago ..Soon as I'd go WOT it cut out immediately..Checked everything I could and was convinced it was a problem in the Msd box changed it out but didn't help at all..after many hrs. Of troubleshooting I was checking the valves on my tank when noticed the o-ring on valve looked dry rotted..Sure enough put a new o-ring on and haven't had a problem since..This probably isn't your problem but I thought I'd post it anyway .
All I can figure is the bad o-ring was letting it suck in air. :dunno:
all connections on lines and tank look good, ran it again, runs great untill wot then it like it starved completely of propane. is this possible?
what ive been told by few Tn boys, i run it without and try hope it cures this pain in the ass stalling!
I run a lockoff on mine. VFF30 and have never had any problems. Had a friend that had a somewhat similar problem and it ended being his lockoff. I wouldnt ride all the time without the lockoff just as a safety precaution but just to see if that is your problem.
thanks for info guys! i took lockoff apart and diaphram was in good shape but when i took filter side apart, filter was black full of ****! cleaned and put back together, so gonna try that and if not take lockoff off and try. i let u kno how it goes
bypassing vacuum lockoff did fix it! so now, buy new vacuum lockoff or a 12v lockoff? Thanks for help guys!!!
I wouldn't waste money on a lockout mine does not bleed off while the motor is not running.
Im no motor expert but my Dads roller 383 doesn't pull enough vacuum and he had to put an electric pump on his car for his brake booster. Could that be the problem at WOT?
I am in the propane conversion business and have been for twenty years. Our shop supplies kits and components for all types of engines and applications and we have many systems on rock crawlers. Are you running your vacuum lockoff on ported vacuum or manifold vacuum? If it is manifold vacuum that would explain why it cuts the engine off. It probably takes a few seconds to choke the engine down before it goes dead. At wide open throttle you have "0" manifold vacuum. Change your vacuum hose to a port on the mixer above the throttle blades and it should help.
There are guys not running lockoffs but it is not advisable. If the vaporizer gets a little piece of debris in the seat it can hold it open and load the motor up when not running.
If anyone needs help you can give me a call @877-403-7827 or email me [email protected].
Buddy
thanks i check on where vacuum is routed, so do vacuum lockoffs go bad? i cleand filter b4 i took it off and didnt help any
The lockoffs do need to be rebuilt occasionally. The diaphragm can get a hole in it especially if you run out of fuel and have a lean backfire. The o-ring and pin can wear and LPG will bypass and enter the engine through the vacuum hose.
