Sold/Expired atlas 4sp, dana 60 & 44, 40in iroks
atlas 4speed transfer case. 1/1 2.72/1 3.8/1 10.4/1 ratios. comes with cable shifters. asking $2800.
call or text Scott 502 802 1557 all prices negotiable
40in swamper iroks and hummer wheels. 55-60% tread remaining. $1500 for the set.
dana 60 rear. spool. 35spline alloy axles. disc brake conversion. 5.13 gear set(the big carrier size) $800
dana 44 front. spool. Superior Axles evolution series alloy shafts. Super joints. 5.13 gear set. High knuckle steering. 6 on 6.5 bolt pattern, but can come with adapters to 8 bolt pattern. $1200
Also (not likely I know) two Tom Woods driveshafts. one is 19in with 1310 joints, one is an offset joint for extra travel. other shaft is 39in with 1310 joints. $75 each.
21 spline input, driver side drop. So 4 cylinder Jeep, is what it was originally on.
